Wraith
Bettyswollocks
I did notice when I took my Founders Edition apart to fit the GPX that it had thermal pads in other areas so I added extra pads to the front and back side of the PCB before fitting the blocks down, also my pumps run a tad faster than 700 - 900 RPM which contribute greatly to my low temps. After 5 hours of gaming I sit comfy at 35c with the i7 around 40c, they both idle between 25 and 27c.
Glad you got your system up and running, once the majority of the micro bubles have moved out you should start to see a great drop in temps.
