maverik-sg1
The specs are easy my friend:
Core 650Mhz, RAM 1600Mhz - 24pipes.
Cheers
Mav
Cheers
Mav
name='Drazic' said:That it from BFG? I've heard higer on the cores
name='Drazic' said:Will be an intresting one how you phase boys are going to cool all 4 gpu's, sure it wont be long before soemthing is made
Drazic said:Possibly cables to plg into the bord and then to the gfx to free them up a bit?
Maybe water only on them, possibly pelt
maverik-sg1 said:Nothing is impossible - but why would you want to do that? - after my SLI 7900GTX's clock past 750mhz the results are processor limited, I doubt if the benefit would in any way outweight the risk involved.
What I am saying is it wont score any better coz the CPU will hold it back.
Mav
name='cheap' said:so at the moment, quad sli is pointless? As there is not a quick enough cpu to unleash the full potential of 4 graphics cards.
maverik-sg1 said:It's unlikely that you be able to do that - it will bring your PSU to it's knees as soon as you start clocking the cards.
A single GTX 7900GTX @ stock running full load will soak up 120w of power (still a lot less than a X1900 though) so quad SLI alone at stock under full load will soak up 480w @ 50a, you need 30a or more for an an overclocked CPU, then you will need a 3-phase supply to power it all![]()
