Much better without the sticker.
Maybe consider a bottom intake fan?
also did you remove the mesh of the roof? looks like its been expertly cut so kudos great mod and nice build![]()
I already ordered one
Thanks but there is no mash in the roof. The only mash i removed is in the side panel.
It could even be a good idea to look into a fan-controller to regulate each fan individually.
What u got mounted in those front-bays?
Yup, did see the SSD. Software-control of the fans is nice, but with splitters u have to regulate pairs right?
Have you considered sleeving your other cables?
a really nice looking rig, besides the cable mess on the back. if you spend a couple hours on fixing those it will be perfect.
where did you get the braided cables from? sleeved them on your own?
Hi there,
Really liking this build. Got me confused for a little while with all that talk of a yellow PSU sticker until I caught a glimpse of it in the first pic.
Two minor details:
If it was my personal rig I might consider painting the heat pipes on the GPU (and if you're getting really, really picky, the brown edge of the GPU PCB with a fine model making brush, but that might be a little too OCD).
I would probably chose black, but maybe black heat pipes and a blue PCB edge would go together nicely? Or the other way around, not quite sure.
Secondly: Presuming the optical drive is absolutely necessary, how about a stealth mod to make it disappear into the front completely?
But as said, overall I think it's a very neat build. Nice choice in the white lighting; I think colour should emanate from the components, not the lighting itself (with a few exceptions).
No, there are no screws - mesh is hold in place with a sort of clamping (bad english-sry) Heres a link to easy mod pics wich u could have found if u did a search on the forum: http://translate.google.it/translate?sl=it&tl=en&js=n&prev=_t&hl=it&ie=UTF-8&layout=2&eotf=1&u=http%3A%2F%2Fwww.hwupgrade.it%2Fforum%2Fshowpost.php%3Fp%3D36385418%26postcount%3D253
Any progress or updates?
