first , want to say Thanks to Corsair for asking me to be part of this special project with these best Modders of the planet, some are my main inspirations and these guy are why I start modding a couple years ago , i'm very honored to be part of this
now this will put more pressure on me, need to make a really good build
I generally try to stay with angels and demons themed build and this one is not an exception,
I named this one "Clear Sky: City of Angels"
the build will be based on the new Corsair Crystal 570x RGB
and for sure, I will paint it all white with silver metallic
I will try to do a special thing on it, first time I will try this and hope the result will be great
Specs
Case: Corsair Crystal 570x
Cpu: "to be determined"
Motherboard: "to be determined"
GPU: "to be determined"
Ram: 16gb (4 x 4) Corsair Dominator Platinum with light bar
PSU: "to be determined"
Cooling: Corsair Hydro Series H100i v2
Fan: 6 x Corsair HD120 RGB LED
Fan control: Corsair Commander Mini
lights: 2 x Corsair Link RGB LED
Modding
not sure if I go with custom water cooling or modded Corsair H100i V2
white metallic paint
silver embossed paint
Blue paint
acrylic
custom cables with white, sliver and blue sleeving and white connectors
some custom vinyl stickers
and lot more, I will update this post at minute I have new things
first
the painting process,
disassembled the whole case
and use car paint,
base coat is Championship White
mid coat is Metallic clear
and for sure clear coat, but not use full glossy one,
generally I used a lot of clear coat on exterior panels and polish them to have a mirror finish,
this one don't have exterior panels and interior panels are very hard to polish, I simply use semi-glossy clear coat instead
some pics pf process
