Hmm you really think its a faulty CPU? Dont know how to RMA it (Im from sweden and bought this from a swedish store). Can you really complain that its not overclocking as wanted to get a new one?
I dont see any wierd temps assuming that the cpu cooler should be a problem. The bsods has come during normal load temps. And bsod code is 124 that gives hint to "more voltage please".
The store said they are not going to take anything back since I have overclocked inte, therefore the warranty is ruined.
I hate lottery, I always loose. I am asking Intel support in chat right now. But they havent respond yet. And if RMA, that may take weeks I guess. And weeks without my computer isnt an option
Ill guess I have to be saticfied with 4.2Ghz...I should have kept my sandy bridge on 4.7 instead : /
I had i 2500K before. But bought myself a whole new system = )
But I must say Im a bit down now with the bad performance for haswell OC
Btw: @ Crazy Teeka, you mentioned LLC to set at High? Im having 1-10 on Load Line Calibration, so whats "high"? I have tryed 5 now.
I think 'high' would equal the max. Since it's calibration it won't damage anything so it's worth a try putting it on 10.
Some Haswell chips are just pigs, looks like you've been screwed by the Silicon gods :l. What thermal paste did you use and how much thermal paste did you put on?
Yes, seems so! Damn Silicon Gods! - Wouldnt argue if some silicon goddess screwed me instead. lol.
I have the arctic silver 5, and hmm, how much, cant say. But temps are looking good? Do you think that it can have anything with thermal paste anyway?
Phanteks PH TC14PE
Idle temps at 25 degrees, and these temps I havent seen with prime or x264 before. Usually stable at max 80-82 under full load, most often around 75 degrees. Now I hit 90 after 25min OCCT.
Sorry for all edits, the 90 was not nocited for me, only looked at max temp. When I looked the temps was always aroun 70-82.
No, you can easily get similar clocks on air if you know what you are doing. I've done a build with a 9590 (yes the overpriced AMD chip) using a Phanteks PH-TC14PE and it was absolutely fine. The temperatures aren't far off from a h100i. The TC14 is about the same performance as the Noctua in this graph.There's your problem, cannot really OC that much on air, you could try an AIO cooler like the H100i or go DIY water cooling. ^_^
Hmm I dont agree there ; ),
I should be able to get past 4.3Ghz even with air, specially with a good air cpu cooler which phantek is. I think its pretty normal to go with air up to 4.6-4.7 at least, maybe after that you can consider water.
Not worth the money. He's got a bad chip it seems.Personally, I'd still try a H100i, give it a go. ^_^
