It should fine tbh, just make sure that it's the 4th PWM pin that's not attached to the header and it should run fine. Also, as it clearly doesnt have PWM the CPU fan will have to run at whatever voltage is coming out of the header, so if you want max cooling it'll have to have the full 12v.
