Building a PC for my mum and her parts arrived today and it just occurred to me that her chip might be better than mine. Details are as title, are these any good?
sounds promising ferret my SL6WK cud only do 3.7Ghz and that was at 1.8v with mach2 cooling but then again was only a 12 capper too now i has a SL6WU the same as gorby
you got ure volt mods done aint u ferret? last night i spent a while trying to find stable settings (not volt modded yet) and seems if i put 1.825 thru the CPU its stable enuff to do most things, but wen i went to encode a HL map which uses multi threads and 100% CPU it crashed i downed straight to 3.75 (as my last chip wasnt stabnle at this) at 1.7v and it was perfectly stable, during load it went down to 1.6v but was 100% stable, roll on vdroop
ive jus got sum new oem p4s in at work. found a 3gig sl6wu 30 capper and also a 2.8m0. the info on the chip if the 3gig are as follows sl6wu malay, L351A889, M401A519,1171. any1 kno if its any good?
warlord, no CPUs are the same man, even if its from a good batch it cud still be complete crap, ure best bet is checking it yourself, having said that, with it being a SL6WU and a 30 capper it sounds promising.
