3d help before buying
queen
hi, i'm going to be buying a lg W2363d and have a couple of questions hopefully you guys can help with...
first being i have read that this monitor is incompatible with bluray 3d, does this mean actual bluray 3d players that would connect using hdmi? in this case would it be safe to assume that i could load a bluray 3d disc into my blu ray drive on my pc and play it thru PowerDVD and it would work in 3d?
also what is the difference between a LG W2363d and a LG W2363d-PF?
thanks guys
Where did you read that it was incompatible with 3D Bluray?
EDIT: from reading numerous sources it seems like it is fine to display 3D Blurays on PC Bluray drive
I've got one of those (W2363d). Overall its great for the money, BUT only if you wan't to use 3D. In 120hz mode you can't change the brightness along with some other settings, so it's very bad if you just wan't run games in 120hz. In 60hz mode it's just as good as a much cheaper monitor. I haven't tested blu ray 3D on it, but youtube 3D etc. works fine.
