i have try overclocking my cpu before and got nothing but trouble and crap result ,
Core Voltage 1.275v
Core Speed 4.4 ghz even try low to 4.2ghz and no ram speed change
Ram Speed 1330 Mhz Using timming for 2400mhz
Ram Volt 1.65v
Now i put the crap results to my noob over-clocking skill but 4 other people others try with no better results. But the ram is the biggest problem
I have went back to stock on my cpu and set timing and voltage on my ram manually
10-12-12-31 Timings 1.65v which are meant of 2400mhz and still cant get 1600mhz to run stable and as of 3 day ago the computer as started Memory dumping and crash as soon as the pc starts up only the first time then it runs fine
Core Voltage 1.275v
Ram Volt 1.65v
