pickyantivirus
Hi All,
I'm sure there have been 100s of these types of posts, but I wanted to get a bit more detail.
I've had my Ryzen 7, 1700X since launch. It's sat under an NH-D15. Today was the first time I've bothered overclocking it. RAM is stuck at 3000Mhz, any higher and it's unstable, so clearly the s**tty memory controller isn't helping me here, as my RAM is 3200Mhz G. Skill, 2 x 16GB sticks.
Anyway, I can only manage 3.9Ghz, at a voltage of 1.43v with LLC set to Level 2. This boosts me from a Cinebench score of 1544 to 1711.
My question here is, real world performance wise, what kind of actual difference will I see. I feel that voltage is a tad high, and temps are about 10C hotter than stock clocks with a max of 68C with the fans on about 900RPM (out of 1500). The reason I ask is, I'm hoping Zen 2 and the 3000 series will offer some serious gains, if they do I'll swap my CPU anyway, but I want to know if it's even worth keeping this overclock or if I should just leave it at stock.
The other question here is, will my Crosshair VI Hero be able to safely run the "rumored" 12 or 16 core Zen 2 chips?
May Thanks,
Ryan
May Thanks,
Ryan
