Kopesetic
So, after I got home from a very long and stressful day at work, I almost lost it finally with the buzzing noise that has been coming from PC since I got the 350D.
For days I have been trying to figure out where the buzzing was coming from and today I finally figured it out and thought I would share just incase anyone else has had this problem.
At least for me, the buzzing was from the bottom PSU filter. Apparently it's kind of a loose fit and when the whole system is vibrating, the filter makes an incredibly annoying and loud buzzing sound.
So there's the tip, if you have a 350D and a very loud and irritating buzzing noise you can't find, check the PSU filter. I simply removed the filter since my PSU doesn't even intake from the bottom and now it's whisper quiet.
Might be time to invest in vibration dampening.
