NRG!
Hi!
Plan:
2 systems sharing pump, res and rads. Get rid of my external mess. Not as crazy as it sounds, I promise.
System 1 is my main rig (in sig), system 2 will be a 24/7 folding rig (powering pump).
Reason:
Original plan when I built this (first custom rig and w/c) was to use my phobya 1260 external rad to cool the two systems. However I'm unhappy with the clutter and ultimately the quality of the rad is poor. It has a very slow leak from one of the bleed ports, even after I replaced the stock plastic stop fittings with brass ones.
I want to build the folder as my nan has vascular dementia. While not targeted by the research (caused mostly by diabetes), the symptoms are very similar to alzheimers. It's a heartbreaking experience to see someone become a different person over a matter of weeks, or see them relive being told that their partner is no longer with us (for example) many times an hour.
My current setup: (warning - large images)
Glam shot
Without intake fans + brackets
Coolant passes through bulkheads (drilled these in)
rad assembly under desk (Filthy!)
That tubing on the rad assembly is actually masterkleer and clearflex60 CLEAR tubing with BLACK mayhems pastel. I've given up on pastel and clear tubing now tbh.
System Spec for the folding rig:
CPU: Intel i7 3770T (45W TDP)
MOBO: MSI z77 GD65 (Have this lying around spare)
RAM: Kingston HyperX grey 8gb (again, spare)
Cooler: Raystorm waterblock (again, spare)
SSD: Undecided, probably Intel 330 or Samsung 840 pro ~60gb.
PSU: 400w Seasonic fanless platinum
case: Fractal Design R4, black
res: either xspc single bay res (again, spare) or EK multioption tube.
pump: D5.
rad: alphacool nexxxos monsta 240 in the front is my plan (2 x 120mm corsair SP quiets - spare)
fittings: bitspower matte black (can't stand shit fittings)
Provisional waterflow:
The pump will feed from the res and pump directly out of the folder to the rad in the main rig, followed by the cpu block, followed by my gpus, before travelling back to the folder, going through the rad, cpu block and back to the res.
This means that when my main rig is off, the 180x3 rad will provide a bit of passive cooling, and while it's on, the 240mm monsta will help it keep everything cool.
Build stage 1:
OBJECTIVE:
Get the alphacool xt45 180mmx3 all copper rad into the bottom of the rv02-e. The key thing here was a custom Demciflex filter that I had made to fit the underside of the case, allowing me to remove all the sliding fan brackets etc. (evem the 35mm magicool rad would not fit with these in because of the length of my gpus).
Problem 1:
These raised sections between intake holes will make mounting difficult. I think I'm going to drill m4 holes and use spacers to mount the fans so that they are level with the top of these raised sections. This should also reduce turbulence from the filter slightly.
Measuring up:
GPUs will just fit!
Need to lose the HDD bays.
Going to need to dremel away these overhangs like Tom did in his rv02 watercooling guide.
Ordered: assorted m4 nuts, bolts, spacers. Alphacool nexxxos xt45 180x3, dremel rotary 3000 and cutting discs, files! (unbelievably, I don't own many tools at all).
Plan:
Reason:
Glam shot
pump: D5.
Build stage 1:
OBJECTIVE:
Problem 1:
Measuring up:
GPUs will just fit!
