12v Power Supply + Adapter for LEDs?
Edge
Hey guys,
I picked up a 1m LED light strip for my desk, but it didn't come with a 12v power supply or adapter to actually connect to the strip.
Does anyone know where I can get a well made 12v 2amp power supply (UK plug) for a 1m LED strip, with an adapter, and with solder-less connections? Dimmer is optional, if it's a good price I'll go for it.
Most have bad reviews, reputation for blowing up, no adapters and no solderless connection xD
For a quick ghetto way, you could always dig out an old 12v adapter from an old drill or something, and use some terminal blocks to join them together. That's how I usually connect them. ( as long as it's not going inside your case )
