Go Back   OC3D Forums > [OC3D] Forum Teams > [OC3D] Benchmark Team
Thread Tools Display Modes
  #1
Old 05-03-19, 07:55 PM
WYP's Avatar
WYP WYP is online now
News Guru
OC3D Cinebench R20 Benchmark Thread
Cinebench R20 has been released, making now the perfect time for a good benchmarking session.
The rules are simple, run Cinebench R20 and report your scores with a screenshot and details about your system. Let's see how all our systems compare!
We will split things into two sections, Single-Threaded and Multi-threaded. This time there is no GPU section of the benchmark to worry about, it's all CPU with R20.
Report your Results like shown below
Score, CPU, CPU Clock Speed, Memory Speed (MHz), OS, Forum Name
Single-Threaded
316cb, Intel i7-5820K, Stock Clocks, 2133MHz DDR4, Windows 10, Wyp
Multi-Threaded
2176cb, Intel i7-5820K, Stock Clocks, 2133MHz DDR4, Windows 10, Wyp
Single-Threaded Charts
1. 543cb, Intel i9-9900K, 5.2Ghz, 3400MHz DDR4, Windows 10, Ofan
2. 536cb, Intel i9-9900K, 5.1GHz, 3333MHz DDR4, Windows 10, Ofan
3. 508cb, Intel i9-9900K, 5Ghz, 2800MHz DDR4, Windows 10, FTLN
4. 487cb, Intel i7-8700K, 4800MHz, 3200MHz DDR4, Windows 10, looz
5. 485cb, Intel 8700k @ 4.7GHz, 3200MHz DDR4, Windows 10, Eddie long
6. 433cb, Threadripper 1920X, 4.2GHz, 3200MHz DDR4, Windows 10, Kei
7. 428cb, Threadripper 1920X, 4.075GHz, 3200MHz DDR4, Windows 10, Kei
8. 426cb, Intel i7-5820K, 4.49Ghz, 2666MHz DDR4, Windows 10, TheStoka
9. 422cb, Threadripper 1920X, Stock clocks ~ 4.15GHz PBR, 3200MHz DDR4, Windows 10, Arne Saknussemm
10. 400cb, Ryzen 1700, 4.0Ghz, 3200MHz 16gbDDR4, Windows 10, KingNosser
11. 397cb, Intel i7-6800K, 4GHz, 2400MHz DDR4, Windows 10, Wyp
12. 394cb, AMD Ryzen 5 1600, 3.95, 3000MHz DDR4, Windows 10, RobM
13. 384cb, i7 4790K, Stock Clocks, 1866MHz DDR3, Windows 10, Wraith
14. 375cb, Ryzen 1700, 3.8Ghz, 3200Mhz DDR4, Windows 10, Kingnosser
15. 359cb, AMD Ryzen 5 1600, Stock Clocks, 2133MHz DDR4, Windows 10, RobM
16. 351cb, AMD Ryzen 7 1700X, Stock, 3200MHz DDR4, Windows 10, Excalibur50
17. 316cb, Intel i7-5820K, Stock Clocks, 2133MHz DDR4, Windows 10, Wyp
18. 284cb, Xeon E5 2683 v3, 3.1GHz, 1100MHz DDR4, Windows 10, Thanos
19. 246, 10/20 Broadwell E ES Xeon, 2.3ghz, 2133mhz DDR4 (8gb), Windows 10, AlienALX
20. 239cb, i7 920, 3.8GHz, 1600MHz DDR3, Windows 7, notcool
21. 221cb, AMD FX-8320, 4375MHz, 1332MHz DDR3, Windows 10, tgrech
22. 201cb, Intel i5-2410M, Stock Clocks, 1333MHz DDR3, Windows 7, looz
23. 185cb, AMD FX-8320, Stock Clocks, 1333MHz DDR3, Windows 10, tgrech
24. 180cb, Xeon x5650, Stock, 1333MHz DDR3, Windows 7, Kei
25. 185cb, Intel Pentium G620, Stock, 1066MHz DDR2, Windows 10, ET3D
26. 116cb, Core 2 Duo E6420, Stock, 800MHz DDR2, Windows 10, ET3D
27. 82cb, Atom x7-Z8750, Stock, 2133MHz DDR4, Windows 10, ET3D
28. 49cb, AMD E-350, Stock, 1066MHz DDR3, Windows 10, ET3D
Multi-Threaded Charts
1. 10270cb, 7980XE, 4.4ghz, 3733mhz DDR4, Windows 10, Kaapstad
2. 10057cb, AMD 3950X, 4.30GHz, 3200MHz DDR4, Windows 10 Pro, Dicehunter
3. 6153cb, Threadripper 1920X, 4.1GHz, 3200MHz DDR4, Windows 10, Kei
4. 6099cb, Threadripper 1920X, 4.1GHz, 3200MHz DDR4, Windows 10, Arne Saknussemm
5. 6096cb, Threadripper 1920X, 4.075GHz, 3200MHz DDR4, Windows 10, Kei
6. 5572cb, Intel i9-9900K, 5.2Ghz, 3400MHz DDR4, Windows 10, Ofan
7. 5440cb, Intel i9-9900K, 5.1GHz, 3333MHz DDR4, Windows 10, Ofan
8. 5421cb, Intel i9-9900K, 5.1Ghz, 2666MHz DDR4, Windows 10, FTLN
9. 4697cb, Xeon E5 2683 v3, 3.0GHz, 1100MHz DDR4, Windows 10, Thanos
10. 3822cb, Intel i7-8700K, 4800MHz, 3200MHz DDR4, Windows 10, looz
11. 3776cb, Ryzen 1700, 4.0Ghz, 3200MHz 16gbDDR4, Windows 10, KingNosser
12. 3661cb, Intel 8700k @ 4.7GHz, 3200MHz DDR4, Windows 10, Eddie long
13. 3531cb, Ryzen 1700, 3.8Ghz, 3200Mhz DDR4, Windows 10, Kingnosser
14. 3326cb, AMD Ryzen 7 1700X, Stock, 3200MHz DDR4, Windows 10, Excalibur50
15. 3136cb, Intel i7-5820K, 4.49Ghz, 2666MHz DDR4, Windows 10, TheStoka
16. 3075, 10/20 Broadwell E ES Xeon, 2.3ghz, 2133mhz DDR4 (8gb), Windows 10, AlienALX
17. 2955cb, AMD Ryzen 5 1600, 3.95ghz, 3000MHz DDR4, Windows 10, RobM
18. 2837cb, Intel i7-6800K, 4GHz, 2400MHz DDR4, Windows 10, Wyp
19. 2813cb, Xeon x5650, Stock, 1333MHz DDR3, Windows 7, Kei
20. 2536cb, AMD Ryzen 5 1600, Stock Clocks, 3000MHz DDR4, Windows 10, RobM
21. 2176cb, Intel i7-5820K, Stock Clocks, 2133MHz DDR4, Windows 10, Wyp
22. 1861cb, i7 4790K, Stock Clocks, 1866MHz DDR3, Windows 10, Wraith
23. 1407cb, AMD FX-8320, 4375MHz, 1332MHz DDR3, Windows 10, tgrech
24. 1263cb, i7 920, 3.8GHz, 1600MHz DDR3, Windows 7, notcool
25. 1173cb, AMD FX-8320, Stock Clocks, 1333MHz DDR3, Windows 10, tgrech
26. 444cb, Intel i5-2410M, Stock Clocks, 1333MHz DDR3, Windows 7, looz
27. 356cb, Intel Pentium G620, Stock, 1066MHz DDR2, Windows 10, ET3D
28. 289cb, Atom x7-Z8750, Stock, 2133MHz DDR4, Windows 10, ET3D
29. 219cb, Core 2 Duo E6420, Stock, 800MHz DDR2, Windows 10, ET3D
30. 91cb, AMD E-350, Stock, 1066MHz DDR3, Windows 10, ET3D
__________________
_______________________________
Twitter - @WYP_PC
  #2
Old 05-03-19, 10:58 PM
Ofan's Avatar
Ofan Ofan is offline
Newbie
Single-Threaded
535cb, Intel i9-9900K, 5.1Ghz, 3333MHz DDR4, Windows 10, Ofan
Multi-Threaded
5423cb, Intel i9-9900K, 5.1Ghz, 3333MHz DDR4, Windows 10, Ofan
https://imgur.com/40x8zFr
  #3
Old 06-03-19, 06:24 AM
AlienALX's Avatar
AlienALX AlienALX is offline
OC3D Elite
Something wrong with this. Well, maybe there's something wrong with my PC.
Firstly my CPU is boosting to 2.3ghz, not 2.4ghz on all 14 cores (as it should) and secondly when running the single core benchmark my CPU is all over the place, ranging from 3.3ghz down to 1.1.
I'm also disappointed with the score, as it should be a bit better than it is but WCYD? At the end of the day I suspect that either the Spectre/Meltdown patches have nerfed my CPU (I would be more leaning toward that) or running different speed RAM is causing an issue, as I can't seem to baseclock my board at all now, nor enable OC Genie.
Either way it is what it is, no point crying over it.
Single Threaded - 236
Multi Threaded - 3937
Edit. I should have the same/faster score than Mark. Doesn't make any sense at all. Single core boost is off.
__________________
  #4
Old 06-03-19, 07:05 AM
looz's Avatar
looz looz is offline
OC3D Elite
Pretty lousy OC all things considered:
Single-Threaded
Multi-Threaded
Screenshot
__________________
i7 8700k - 16GB - 2060 FE - 660p 1TB + MX500 2TB - HE-4XX w/ Topping D30+A30
  #5
Old 06-03-19, 08:51 AM
WYP's Avatar
News Guru
I will update the list in a bit, but I believe that the new CInebench uses AVX instructions, so boost clocks wouldn't be as high. AVX is a huge power hog, but it is one of the ways that the newer versions of Cinema 4D runs faster than its predecessor.
__________________
Twitter - @WYP_PC
  #6
Old 06-03-19, 09:30 AM
AlienALX's Avatar
OC3D Elite
This is true but does not explain the chasm between a stock 5820k and my CPU in single thread score given my single core boost is supposed to be 3.1 ghz around dead even.
I'm also pretty certain it should not be throttling at 1.1ghz on single core. Heck, it runs them all at 2.3 under load ffs.
I'm wondering if it's the Windows Store somehow? Gawd knows. Way to alienate your users though.
__________________
  #7
Old 06-03-19, 09:40 AM
looz's Avatar
OC3D Elite
You can download a portable version of it via TechPowerUp or Guru3D, if going through Windows Store bothers you.
__________________
  #8
Old 06-03-19, 09:48 AM
WYP's Avatar
News Guru
Please use the same format as the other posters when listing your results. For example, I do not know your memory speed etc.
Single-Threaded
Multi-Threaded
Screenshot
Still miles ahead of my PC, though it is my office system. Will need to try the 1700X later to get some AMD in here.
Shouldn't be. AVX could be a bigger power hog on older CPUs. Hard to know.
CPU scaling should be fine, as this bench is designed to work well with even AMD's newest 32 core CPUs. Could just be a quirk of older Xeons.
Originally Posted by Ofan View Post
Single-Threaded
Multi-Threaded
And we have our first chart-topper. Congrats. That will be a hard single-threaded score to beat.
__________________
Twitter - @WYP_PC
  #9
Old 06-03-19, 11:23 AM
AlienALX's Avatar
OC3D Elite
What I have is a generation newer than the Haswell 5820k. It's Broadwell E, so it *should* have IPC around 5% higher than the 5820k, offsetting the 100mhz defacit I have. My RAM speed? in my sig fella, top link. 2133, which is why I didn't bother posting it.
My CPU won't overclock since adding four more DIMMs (2400mhz but running at 2133). Maybe that has something to do with it?
But yeah, when I got the CPU in June '17 I benched it and the results were the same on one core as my 5820k I replaced. So something is badly amiss when the CPU is clocking to 1.1ghz.
__________________
  #10
Old 06-03-19, 11:26 AM
tgrech tgrech is offline
OC3D Elite
Yeah I can't install it on my laptop via the MS Store because the store says it is unable to read my RAM amount and so can't verify I meet the Minimum requirement of 4GB. Might have something to do with the fact it's still on the original October update that actually released in October as opposed to the 2019 "October" update which I can't actually update to via update. Might have to force the update with a pen drive and try again since I'm getting security warnings now. But two potato PC (FX8320 and i7 3612QM [35W Ivy Bridge Quad Core]) benchmarks on the way at some point (I'm interested to see how these two 2013 architectures stack up against modern parts, I might go back and try an OC on the FX8320 at some point, used to get an extra 1Ghz over stock with that part).
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
