Go Back   OC3D Forums > [OC3D] Off Topic > Off Topic Chat
  #11
Old 09-03-21, 02:56 PM
AlienALX's Avatar
AlienALX AlienALX is offline
OC3D Elite
If it is anodized you really ought to remove that first. Oven cleaner gets rid of it. And yes, even if it's silver it will still be anodized to stop it corroding in the air.
If it's raw metal you will need to blow it with self etching primer first. If you don't it will literally side off afterward. Then go into primer.
__________________
If you don't like what I post don't read it.
  #12
Old 10-03-21, 03:37 PM
Pugsport Pugsport is offline
Advanced Member
im not trying to undermine you Alien but Etch and Wash primers are now pretty old school in the automotive painting industry but i do get that if your going to be painting at home you may not have access to a compressor and a paint gun or may not want to spend the extra money on different products but epoxy primers and sealers are the products 90% of painters now use for bare metal because it has a lot of advantages over etch primers.
Etch primer: -
Positives - good for bonding to bare steel and aluminium, cheap and easy to get hold of.
negatives - not waterproof, can not apply 2k fillers over the top of it as putting a 2k filler over the top of it will soften the etch primer and they will both stay soft afterwards. This is not so good in the automotive industry as the filler is not sealed on both sides from moisture. i get here it in the computer world it wont be so much of an issue but id still rather do any filling over paint than on to bare metal
Epoxy primer: -
Positives - will stick to bare steel, copper, aluminium, galvanised steel, aluminium alloy. 100% waterproof so good for long term projects that may sit around for a while, can apply filler over the top of epoxy primer with no issues, has a 24 hour to 48 hour time frame before over painting it without the need to key the surface up. you can also paint it wet on wet if needs be (you paint over it after its flashed off meaning you dont have to wait for the epoxy to dry before apply a standard primer or colour)
Negatives - the only two drawbacks with epoxy i can think of are the fact you really need to apply it with a paint gun although you could apply it with a paint roller or paint brush and its a bit more expensive than Etch or Wash primer
  #13
Old 10-03-21, 03:56 PM
AlienALX's Avatar
OC3D Elite
You are supposed to use a sealer.
It was good enough for BOM so it's good enough for me tbh. Like I said, you don't even use a whole coat of it. Just literally a dusting for your primer to grab to.
__________________
  #14
Old 10-03-21, 05:30 PM
tinytomlogan's Avatar
The Guvnor
Car spray shop is the way if its a very specific colour tbh
__________________
If you recommend a product LINK THE REVIEW
Get along or run along. Your choice
  #15
Old 10-03-21, 06:43 PM
dipzy's Avatar
dipzy dipzy is offline
OC3D Elite
Wow, I appreciate all the responses
I'm not in a rush to get this done so I may try out a few test pieces, see how they come out but also get some quotes from a spray shop
__________________
| Asus X399 Zenith Extreme | AMD Threadripper 1900X | 32GB Gskill Trident Z RGB | Nvidia Titan Xp | Western Digital 500GB & 512GB NVME M.2 SSDs | Corsair AX1500i | LG 32" 4K HDR Monitor | Ducky Shine 3 YOTS Edition | Corsair M65|
  #16
Old 11-03-21, 02:15 PM
The Guvnor
Thing to remember if you DIY is acid etch and normal etch primer are different.
If you use etch primer you need to make sure that you use a normal primer over the top because it can react with the colour coat and cause blisters
Acid etch will adhere better though - if the case is annodised you will need to make sure you spend a lot of time sanding the case first - it needs to look dull before you start the painting
__________________
  #17
Old Yesterday, 08:05 PM
dipzy's Avatar
OC3D Elite
Ta Daaaaa!!!! All done
Got it done by a custom spray shop in KY0 Silver with carbon accents at the front and top I/O strips.
I'm fairly please with the result
__________________
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
