Go Back   OC3D Forums > [OC3D] Processors & Platforms > Mainboard & CPU
Thread Tools Display Modes
  #1
Old 24-05-17, 03:20 PM
bazskating's Avatar
bazskating bazskating is offline
Newbie
New build advice please
Hi so my brothers pc needs upgrading!
He has about 600 to spend on a motherboard, cpu, ram and a cooler what would people recommend?
His main use currently is for gaming but he has also expressed that he may like to give streaming a go at some point he also uses photoshop occasionally.
Any advice would be greatly received
Thanks Baz
  #2
Old 24-05-17, 03:49 PM
Tolemac's Avatar
Tolemac Tolemac is offline
OC3D Elite
Give us the specs of the PC he is currently using and we can help him more
__________________
Build Log: http://forum.overclock3d.net/showthread.php?t=72241
“If you knew the magnificence of the three, six and nine, you would have a key to the universe.” – Nikola Tesla
  #3
Old 24-05-17, 10:20 PM
bazskating's Avatar
Newbie
It's an old amd rig will try and find out what it is, the psu has died so seems a good time to upgrade the other parts too! The psu doesn't need to be purchased within the budget above was thinking of an rm650x for the psu
Update it had an gigabyte fm2+ motherboard and I seem to recall it having an APU CPU but cant remember what it was.
  #4
Old 24-05-17, 11:07 PM
AlienALX's Avatar
AlienALX AlienALX is offline
OC3D Elite
So he has a GPU already? We do need more specifics tbh.
__________________
  #5
Old 24-05-17, 11:28 PM
bazskating's Avatar
Newbie
sorry didn't think I would have to list what he had already, he's currently using my old 580 GTX with plans to upgrade around Christmas time to a newer GPU.
__________________
Corsair 750D | Asus formula VI | I7 4770K | Nvidia reference 970 GTX | 16gb Corsair Vengance 1600mhz | Corsair RM650 PSU | Corsair H105 CPU cooler in p/p
  #6
Old 25-05-17, 12:56 AM
AlienALX's Avatar
OC3D Elite
I would aim for a Ryzen 1600, B350 board (half decent, say £100) 16gb ram and pretty much any cooler you like. They don't run particularly hot and are not limited by temps unless you have a really poo cooler.
__________________
  #7
Old 25-05-17, 12:58 AM
bazskating's Avatar
Newbie
AMD Ryzen 5 1500X 3.6GHz Quad Core (Socket AM4)
ASUS PRIME X370-PRO AMD Socket AM4 Motherboard
Corsair Vengeance LPX 16GB (2x 8G 3000MHz DDR4
Corsair Hydro Series H100i v2 High Performance Liquid CPU Cooler
Having a quick look I've put together this does it look to be ok? any recommendations?
__________________
  #8
Old 25-05-17, 01:21 AM
Excalabur50's Avatar
Excalabur50 Excalabur50 is offline
OC3D Elite
Swap the board down to a B series and up the CPU to a 1600 and you'll be good to go
__________________
DRAGON'S MIST
Coolermaster H500P White ARGB=AMD Ryzen 3700X=MSI MPG X570 Gaming Pro Carbon WiFi=Intel Optane SSD 9 480GB PCIE=32gig 3200Mhz GSkill Flare X= Sapphire RX5700XT Nitro Plus=Coolermaster ML360R ARGB=MSI Optix MPG341CQR=MSI GK80 Vigor=Corsair Force LS 960GB=Roccat AIMO White=EVGA Supernova 850 G2=White Sennheiser Game One=NZXT Hue+ with RBG strip=Windows 10 Pro=Thrustmaster T16000M HOTAS=Razer Firefly RGB CE=Soundblaster ZXR
  #9
Old 25-05-17, 01:25 AM
AMD Enthusiast
What gpu is he looking at as well?
Would be worth it to drop down to a B350 board and a cheaper CPU cooler to spend more on the GPU and get a 1600. Which will benefit him a lot for streaming and Photoshop
  #10
Old 25-05-17, 10:19 AM
bazskating's Avatar
Newbie
haven't looked at GPU's yet as it will be 6 months away before we upgrade it, but will be somewhere like a 1070 or AMD 580.
so ryzen 5 seems to be the right way to go? i5 isn't worth looking into?
the reason I'm drawn to AMD is because it seems to be performing rather well and also they don't seem to change there sockets every other year so leaves him more of an upgrade path with just a new CPU at a later date.
so just juggle those components around to see what I can get within the budget
__________________
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
