Go Back   OC3D Forums > [OC3D] Cooling Forum > Air Cooling
  #11
Old 16-11-11, 10:48 AM
Veloxzr Veloxzr is offline
Newbie
Thanks a lot for the help, Just wanted to make sure they'd work with x58
__________________
|i7 950 @ 4GHz|G.Skill 12GB 1600MHz|Noctua NH-D14|Gigabyte X58-UD3R|GTX 560ti SLI|
|Silverstone 650W 80+ Gold|60GB SSD Boot|2TB HDD Storage|Antec 12 Hundred Chassis|
|ASUS 24" LCD Monitor|Mionix Zibal 60 Mechanical Keyboard|SS Kinzu v2/IMO 1.1 SS Mod Mouse|
  #12
Old 16-11-11, 10:17 PM
fcb fcb is offline
OC3D Elite
Please forgive my forgetfulness. Since you're running a X58 system, a 3x2GB kit is preferable since triple channel memory is supported. If you think you'll need more RAM, 3x4GB kits are available as well.
__________________
http://www.pacificfirstaid.ca | e-mail: [email protected]
Authorised Canadian Red Cross Training Provider
Give the gift of safety.
  #13
Old 17-11-11, 02:14 AM
Newbie
No problem Since Ripjaws x 2133 don't come in 3x2GB or 3x4GB kits, should I just go with Ripjaws 3x4GB 1600 or something like Corsair Dominator 1600 3x2GB and take the top part of the heatsink off? Sorry for asking so many questions :\
__________________
  #14
Old 17-11-11, 03:52 AM
fcb fcb is offline
OC3D Elite
No worries. If you can find a 3x4GB kit running at 1600MHz, that will be fantastic. Kingston HyperX has some great selections as well. HyperX RAM all use the RAM-height heatsinks so you won't have any compatibility issues with them under the D14. Since DDR3 memory doesn't get hot at all, there's nothing for you to worry about.
__________________
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
