Yesterday my XSPC Rasa 750 RS360 kit finally came in after being backordered.
I have a question or two about WC, my first adventure into the area, ((getting my feet wet so to speak)(god I hope not)).
Here was my normal start temp using the stock Intel air cooler.
Then a short Prime95 run.
Everything looks fine, but the one core that is almost 9C lower than the other cores.
The XSPC rasa 750 RS360 was installed last night, if you want head over to the Build Log to see my post there, about my new system and how the build is progressing.
After the water kit was installed these are starting temps.
And then another short Prime95 run.
Again there is the 10C difference between the hotest and coolest core.
So finally to my questions:
Is that normal for there to be ~10C diffences between the highest and lowest cores?
Could the termal paste not be spread correctly? I used the "rice" size in the center of the chip when I applied the paste.
This weekend or sooner, I'll be starting to over clock the system, but because this is my first adventure into water cooling I wanted to make and get reassurances that things are working correctly before I nuke something.
