Hi guys,
I was just wondering if the Rasa 750 RS240/RX240 Water Cooling kit is compatible with the Obsidian 650D case?
RX240
RS240 Seems to have more clearance?
There was a recant Video review made by TTL on YT in which he said that the Radiator will have clearance issues with the Gigabyte UD7 motherboard. It happens that I have a Gigabyte UD7 motherboard in a 650D case, so if the RS or RX240 Radiators wont fit I will have to consider looking at other Radiators that are compatible.
I would happily consider purchasing separate components if the Rad does not fit.
I would also appreciate it if you guys could recommend ideal tubing width for my water cooling project and compression fittings. I only want to build a single loop configuration for the CPU with a bay reservoir.
RX240
