XMS Project: [F40]
how about cherry red sides, black top (resprayed to match finish of sides) + black front?
what are you using to spray it? if youre using high quality paint nozzles or getting done proffesionally or w/e, what about a fade? from dark cherry red at the back to black at the front?
Powder coating...so i dont really have that option :(
This is going downhill fast...
The site which cut the mesh window in my case decided they would use glue to stick it to the case panel, after i specifically stated NO GLUE.
This means that the powder coaters are unable to spray this panel as the glue would simply mess the finish up.
Needless to say i'm a little annoyed.
I can't really stick the water cooling in until i get the top of my case back. The sleeving is actually techflex from kustompc's. Everything red that acryan do is actually pink :(
Just ordered some Red LED's to replace the power lights in the front of my case too. About to see if i can afford a Saitek Eclipese Red atm :p
