30/07: First parts to arrive is the fans. These come with molex connectors normally so i had to solder some 3-pin cables on for the CrystalFonts fan header. I've also added fan grills and silicon gaskets to each of them...
31/07: Lush XSPC radiator came through. Installed fans and PTFE taped the barbs on. Also installed the Crystalfontz display into a 5.25" drive bay mounting kit:
02/08: Case is on its way back from KustomPC's all cut up
- Next up is quite possibly a powder coat finish in red or dark blue
07/08: Something has happened to my case
The panels are on their way out to be resprayed in dark red and black.
17/08: A few bits of Conroe goodness have arrived
26/08: Today i spent pretty much the whole day sleeving my PSU and replacign the connectors. Camera made the sleeving look slightly orange, but its deep red in real life. I also souldered 3-pin cables on all my case fans and got rid of the annoying moex connectors.
I've been told that my resprayed case will be with me on Wednesday
31/08: Resprayed case panels are slightly delayed and should be with me tomorrow. In the meantime i did a few small things like chaging the blue LED's on my power/hdd lights over to red..
01/09: Panels came back!! Here are a couple of teaser photo's before the full review coming up on the site in the next few days
04/09: Water cooling installed, NB cooler installed and touchscreen TFT installed....
16/09: After switching NB cooler, the mosfets needed some cooling...
16/09: Ordered some Genuine Ferrari stickers. These ones are used on the side of the 355 and other models. So what a better place to put them, than on the side of my case
03/10: Ok some of the worst pictures yet, but i couldnt wait for daylight to take these pics
Unfortunately nobody would cut the window for me so i've resorted to a temporary solution....
I have installed "limmo black" car window tint to the Stock Silverstone window, and installed the screen behind it. Looks pretty good imo.
28/10: Got fed up with the mediocre temperatures from my water cooling setup....so i decided to ditch the radiator and install a chiller
Water temperature goes down to 4oc when PC off and 9oc with it on. CPU runs at around 16-18oc load and sometimes if i leave the chiller on without PC on, ice starts forming in the loop
