XMS: Project [F40]
JN
Thought it was about time i added my latest creation to the gallery:
Silverstone TJ03 Aluminium Case in Ferrari Red + Annodised Black
Asus Commando (New NB Cooler + Sinks)
Intel Core Duo X6800 ES
OCZ PC2-8800 Gold XTC
XSPC Dual Radiator
Laing D5 Pump
1/2" Danger Den Red Tubing
2x Delta 140cfm fans
2x Thermaltake Thunderblade 120mm Red Fans
2x Thermaltake Thunderblade 80mm Red Fans
Super Flower Fan Controller
Enermax Infiniti 720w - Sleeved in Red
XFX 7900GT - Watercooled
7" touchscreen TFT mounted inside case :p
get.php
get.php
get.php
get.php
get.php
get.php
get.php
get.php
get.php
Cheers lads.
@ali_james: The rig has LED strips rather than cathodes and can be set to permenantly on or random sequences using a hidden button on the front of the case :)
Fantastic job. Did you send the pics off to any mags or anything yet?
And what did you use to fix on your mosfet sinks?
Not yet - i will get around to it tho.
They are stuck on with the Arctic Silver bonding stuff - works quite well on small, light things.
