xms pro with dfi board???
Raging
i have 2gb of ddr400 xms pro ram(twinx2048-3200c2pro)i dont know much else about it tbh and was wondering if it will work with a dfi board?
as i have been lead to beleive it wont:eh:
cheers.
cheers.
dfi and corsair bad combinations :mad:
DFI and Corsair - Kingston don't work well. Kingston has about a 50% failure rate as does corsair. DFI's are the best motherboards and are very picky when it comes to certain things especially ram, DFI lanparty's work best with a nice TCCD based ram which is not corsair ;)
Corsair will work on a DFI board and will OC
There's some guides on the DFI forums for DFI + Corsair
Admittedly other stuff works better :)
hmm i was just browsing through dfi street, and it seems alot of people have troubles with corsair and there lanparty's erroring at stock
I run Geil 2X1gb but i have some Corsair Value Select 2X1gb which works fine in my DFI aswell.
I have never had a memory compatabilty problem.
Sam
Sometimes the DFI's take a bit (or a lot) of tweaking in order to get things (especially memory) running correctly.
But as long as you have patience, and can read forum posts, then there is no reason why your memory shouldn't work pretty well with the board.
Sam
tried running the corsair on its own yet?
ooo i have plenty of patience:D
thanks again for all you help ppl
cheers.
