Well, first i've checked about various forums for a watercooled xigmatek elysium build/project log, can anyone find one?!
I can't find one and would really appreciate to see what it looks like with the watercooling equipment in.
Secondly, can anyone recommend anything based on this (from reading the rules and other posts I'm guessing I can link to this, due to fact its easier than posting a list, if not then i'll add a list instead of linking)
YOUR BASKET
1 x Xigmatek Elysium Full Tower Windowed Case - Black £149.99
1 x OcUK D5 Vario Pump & EK D5 X-Top V2 Value Combo £81.98
1 x EK Supreme HF CPU Waterblock - Nickel Plexi **2011 Compatible** £49.99
1 x XSPC EX360 120mm Radiator - Black £49.99
1 x EK Multioption Reservoir X2 250 Advanced £38.99
1 x Lamptron FC5 V2 5.25" Bay Fan Controller - Black £34.99
1 x XSPC Single 5.25” Bay Reservoir - Multi Fascia £24.98
1 x Masterkleer Hose Pack PVC 15,9/11mm (7/16ID) Clear 3.3m £10.88
1 x OcUK Tube Cutter Aluminum 3-14mm £8.50
2 x Mayhems X1 UV Oil Black Premixed Watercooling Fluid 1L £7.99 (£15.98)
6 x BitFenix Spectre LED RED 120mm Fan £6.49 (£38.94)
1 x Masterkleer 7/16" ID [16/11mm] Tubing Clear/UV Blue £3.74
4 x EK-PSC Adapter Rotary 45° G1/4 Nickel £3.59 (£14.36)
11 x EK PSC Compression Fitting 7/16 [16/11mm] - G1/4 - Nickel [3831109845011] £2.99 (£32.89)
4 x EK 12mm (1/2") G1/4 High-Flow Fitting £2.96 (£11.84)
1 x OcUK Value PSU Bridging Connector (24 Pin) £1.30
50 x PrimoChill Barbed T - UV Red - 1/2" £0.01 (£0.50)
Total : £590.17 (includes shipping : £16.85).
I'll also by buying a few items from SpecialTech;
G1/4 T Fitting - £2.59
Sealing Plug 1/2" ID - £3.29
--- Below is the red BitFenix Alchemy range ---
6x 3 Pin Fan Cable Extension £21.90
2x 6 Pin PCIe Power Extension £13.58
4 Pin ATX12V Extension £4.19
ATX 24 Pin Extension £7.95
* The 2 res's are in there until I can make me mind up (as from watching the review it's a huge case and could look a bit empty without a tube res, one of the main reasons I want to see a project/build log
** 50 T-Lines are in there just for the sake of them being 1p per
Thanks!
YOUR BASKET
Thanks!
