Windows 2008 R2 - Antivirus
Hay11Mac
Hi Guys
I'm after some antivirus software for my home server which is running Windows 2008 R2. My current antivirus has run out, and is quite expensive to renew.
Can anyone recommend and good one??
Thanks
Hay x
I use Microsoft Forefront Endpoint Security (I'll have to re-check the name when I get home to be sure though). It's basically MSE for the Server environment.
