Windowed cases but window on the right (READ)
wrenaudrey
Im trying to find a case that has a window on the right side
"Right side" you say:
When facing the front of the case, the window panel is on the right.
Obviously with the window panel on the right, the motherboard position is also the other way round, so when you look through from the right side you'll still see the motherboard and not the tray with a big cpu hole :lol:
PS. How do I upload pictures? I wanna upload some so you can see my situation on why im trying to find this weird as heck case.
Silverstone TJ11, but it's expensive as ef.
You'll have to find a case with an inverted motherboard tray. There may be one with a window, otherwise you'll have to mod one yourself :)
If you're handy with tools and comfortable working with cases, I suggest to find one you like, preferably with stock side panels and invert the whole motherboard tray and then cut the right side panel to your liking, easier said than done haha.
as for the pictures, i personally upload them to photobucket first, then use the insert image option within the forums and insert the direct link, this part is actually easier done than said :)
What you are looking for is a case that suffers from "reverse ATX layout"
syndrome :lol: (I have one myself, see here).
Besides the TJ11, there's also the Silverstone FT02, which is available in a
windowed and non-windowed version. However, it is not exactly cheap
either. There are a few build logs around here using that case if you wish
to have a look at what can be done with it. The Raven RV-02 also has
its window on the right side and is more affordable, but uses a lot of plastic.
Then there are Caselabs, of course, which are worth their price, but the
price is high. Have a look at their website for more info. I'm not sure if
all their smaller cases can be had in reverse ATX, you'll have to check,
but the bigger ones can be.
LD cooling also make a case in reverse ATX, the PC-V8. However, that
too is quite expensive and large.
Happy hunting :)
I'm sure one of the cheaper Bitfenix cases is reverse, but it hasn't got a window, it has just a plain panel, so it would be easily modded. I'm unsure of the name the Raider, or ghost ? it is one around the same price range.
It's the Bitfenix Outlaw mate :)
