This should be in the right place, but move if needed
The last few days, my internet has been used on my second machine, and gave me ample time to go through my system and uninstall all the junk I've put on it over the past 12months.....
I ran a deep search scan and my Avast found 5 results:
3x PUP - Potentially UnWanted Programs which were found on my E: and F: drives, but these are trainer programs and are false positives so have discarded these.....and since put them onto a MicroSD card so are off my system. (re-scanned the file locations and came up clean)
The other 2 are the Win32-Rootkit-gen and were found:
C:\Program Files (x86)\x264 Video Codec\Filters\Haali\mmdinfo.dll
C:\ProgramData\Microsoft\Media Tools\MediaIconsOverlay.dll
Now for some reason a simple Move to Chest wasn't working for me, so dug a little deeper and the x264 Video Codec I installed turns out to be un-used and have successfully uninstalled it through Program and Features.
I then went exploring to the Media Tools folder, and inside were 2 more folders.... 'Plugins' and 'Temp' both of which were empty and the MediaIconsOverlay.dll file.
I've Deleted the dll file and did a restart and went back to check to see if the file had reappeared... and no it didn't so, so far so good.
So now my system 'looks' clean.
I've set up Avast to run a Boot-Time Scan on the next time my PC powers up searching only the C:\ as drive E and F were clean.
Anything else need doing?
EDIT: Malwarebytes scan is clean.
