Win an MSI 7770 with OC3D & AMD
Status
Not open for further replies.
how i would build system around a AMD 7770
Crucial m4 128GB http://www.aria.co.uk/Products/Storage/Hard+Drives+-+SSD/100GB+-+260GB+SSD/Crucial+m4+128GB+2.5%22+SATA-III+Solid+State+Hard+Drive+?productId=44258
Windows 7 Home Premium 64 http://www.aria.co.uk/SuperSpecials/Other+products/MICROSOFT+Windows+Home+Premium+7+SP1+64-bit+EN+1pk+-+OEM+%5BGFC-02050%5D+?productId=38272
Intel Core i5-3570K http://www.aria.co.uk/SuperSpecials/Other+products/Intel+Core+i5-3570K+3.40GHz+%28Ivy+Bridge%29+Socket+LGA1155+Processor+-+Retail+?productId=49755
MSI Z77A-GD55 http://www.aria.co.uk/Products/Components/Motherboards+-+Intel/Socket+1155+-+Intel+Z77/MSI+Z77A-GD55+Intel+Z77+Socket+1155+DDR3+PCI-Express+Motherboard+?productId=53349
1TB Western Digital Caviar Black Hard Drive http://www.aria.co.uk/Products/Storage/Hard+Drives+-+Internal/3.5+Inch+SATA+Drives/640GB+-+1TB/1TB+Western+Digital+Caviar+Black+WD1002FAEX+3.5%22+SATA+III+Hard+Drive+?productId=40242
8GB Corsair Vengeance Blue Low Profile http://www.aria.co.uk/Products/Components/Memory+-+RAM/DDR3/Dual+Channel+-+%281600MHz%29/8GB+%282x4GB%29+Corsair+Vengeance+Blue+Low+Profile+1600MHz+CL9+DDR3+Dual%2FQuad+Channel+Kit+%5BCML8GX3M2A1600C9B%5D+?productId=45510
650W Corsair HX Series V2 http://www.aria.co.uk/Products/Components/Power+Supplies+-+PSUs/Modular+650W+or+less/650W+Corsair+HX+Series+V2+80PLUS+Gold+Modular+Power+Supply+?productId=51860
be quiet! Shadow Rock Pro http://www.aria.co.uk/Products/Components/Coolers+-+Air/CPU+Coolers/be+quiet%21+Shadow+Rock+Pro+Quiet+CPU+Cooler+?productId=52943
Fractal Design Arc Black Midi http://www.aria.co.uk/Products/Components/Cases/Midi+Tower/Fractal+Design+Arc+Black+Midi+Tower+Case+?productId=49982
All together it costs £744.87
CPU:
Intel Core i5-3570K 3.40GHz (Ivy Bridge) Socket LGA1155 Processor - Retail #49755
https://www.aria.co.uk/SuperSpecial...t+LGA1155+Processor+-+Retail+?productId=49755
£ 134.95
CPU Cooler:
Noctua NH-D14-2011 Dual Fan Quiet CPU Cooler #53260
https://www.aria.co.uk/Products/Com...11+Dual+Fan+Quiet+CPU+Cooler+?productId=53260
£ 49.98
Storage:
SSD:
Crucial m4 128GB 2.5" SATA-III Solid State Hard Drive #44258
£ 76.66
HDD:
1TB Seagate Barracuda ST1000DM003 3.5" SATA III Hard Drive #48501
https://www.aria.co.uk/SuperSpecial...003+3.5"+SATA+III+Hard+Drive+?productId=48501
£ 44.95
Motherboard:
MSI Z77A-GD55 Intel Z77 Socket 1155 DDR3 PCI-Express Motherboard[/URL] #53349
https://www.aria.co.uk/Products/Com...DDR3+PCI-Express+Motherboard+?productId=53349
£ 87.77
RAM:
8GB Mushkin Enhanced BlackLine Frostbyte LV #996988 (2x4GB) 1600 (PC3-12800) 240-Pin DDR3 SDRAM CAS 9-9-9-24 1.35V
#43961
https://www.aria.co.uk/Products/Com...DR3+SDRAM+CAS+9-9-9-24+1.35V+?productId=43961
£ 26.31
PSU:
650W Corsair TX650 V2 80PLUS Bronze Power Supply #53134
https://www.aria.co.uk/Products/Com...2+80PLUS+Bronze+Power+Supply+?productId=53134
£ 58.95
Case:
Cooler Master HAF 912 Plus Black Midi Tower Gaming Case #42044
https://www.aria.co.uk/Products/Com...Black+Midi+Tower+Gaming+Case+?productId=42044
£ 53.57
I'm building this in the CoolerMaster HAF case, which I realize is not the most visually pleasing machine, but its open mesh spacious design and its 200mm fans cool very very good. Put a fancontroller in and you can switch to a nearly silent machine (with the fancontroller on the one hand and a quiet CPU cooler in combination with the right bios settings.
That's why I'm adding a fancontroller, a 200mm fan (for the top) and a 140 mm fan (for the side). The case comes with a front 200mm fan and rear 120mm fan pre-installed.
140mm:
Corsair Air Series AF140 Quiet Edition 140mm Quiet Fan #50721
https://www.aria.co.uk/Products/Com...uiet+Edition+140mm+Quiet+Fan+?productId=50721
£ 10.60
fancontroller:
Zalman ZM-MFC3 5.25" 4 Channel Fan Controller - Silver #50789 £ 29.18
https://www.aria.co.uk/Products/Com...nnel+Fan+Controller+-+Silver+?productId=50789
£ 29.18
200mm:
Cooler Master MegaFlow Red LED Quiet Case Fan 200mm #50013 £ 9.27
https://www.aria.co.uk/Products/Com...Red+LED+Quiet+Case+Fan+200mm+?productId=50013
£ 9.27
All that with £37.78 to spare. A total of £712.22, VAT & delivery included:
£ 582.19 excl VAT
£ 11.33 Delivery
£ 118.70 VAT
Status
