Will this be a good Water-Cooling setup ??
Have fun getting an PA120.3 in the drive bay area, you won't fit anything else in there if you do. You'll have to mount it externally or on the ceiling of the case; in which case you'll be stretching it there too due to the raised usb/handle part at the front. The 810 were designed to have a radiator placed on the rear (externally)
Hm, I have seen ppl mounting their PA120.3 at the bottom of the case (Stacker810) where there is the mesh air duct, So if i just remove that mesh n do a bit of modding like drilling the screws n cutting it a BIT i think i will be able to mount the RAD there.. Like
RAD
Fans
Case
WIll that be a good idea ?? i will mount the PSU on the top.
@Kemps, Lian Li is unfortunately isnt available in my country :o
name='PV5150' said:
Oh yes I'd forgotten about the bottom meshed area, my bad. That will be fine :)
:D :D
aright i was just thinking if those cheapos 120mm fans that have very moderate CFM (around 50-55) go good with the PA120.3, i can get them for 90Rs (ie 2$) here. n they are barely audible.
