S_I_N
Ok so pricing out my wc setup just gonna be cpu (might add gpu later is why the 360 rad) Now I am far from new to wc but it has been a long time since I have done it and things have changed alot since then (just used distilled water back then) heres what I currently have priced out but the only thing I am uncertain of is the fluid I chose. This prices out to 335$ USD prior to shipping. I found a similar kit (only diff is its the black Rasa XSPC block versus the Rasa Ultimate. And it priced as a kit for 190$ USD minus the 45degree fittings and fluid. Just wanted opinions about the fluid and the difference between the blocks I'm assuming the Ultimate is a better performing block. Anyways thansk for looking and commenting.
ex-liq-10 PrimoChill ICE Non-Conductive Liquid Cooling Fluid (32 oz.) - Clear $19.99 $39.98
ex-tub-432 PrimoChill PrimoFlex PRO LRT Tubing 7/16"ID 5/8" OD with 3/32" Wall - Clear $2.25 $22.50
ex-res-161 XSPC X2O 750 Dual 5.25" Bay Reservoir Pump $76.95 $76.95 ex-blc-771 XSPC Rasa High Performance Acetal CPU Liquid Cooling Block (Sockets LGA 775 / 1155 / 1156 / 1366) $66.99 $66.99
ex-rad-146 XSPC RX360 Triple 120mm Radiator Rev 2. $101.99 $101.99
ex-tub-628 Bitspower G1/4" Matte Black Rotary 45 Degree G1/4" Adapter (BP-MB45R) $12.99 $25.98
Another note I may have to go with the 240 rad depending on fit. I'll be taking the Storm Sniper thru this process and still need to measure everything out. Oh and also this does not include fans where-as the XSPC RX360 and RX240 kits do. But thats not a major concern for me as I will very likely use Green Sickle Flows. Above is the singly priced parts and below is the kit
Product Details:
New Rasa 750 RX360 WaterCooling Kit from XSPC!
Features/Specifications:<br style="font-family: tahoma,arial,helvetica,sans-serif;">
AMD Sockets 939, 754, 940, AM2, AM3
Intel Sockets LGA1366, LGA1156, LGA775, 603, 604
*Requires mounting holes
Designed for multi-core CPUs
http://www.performan...oducts_id=30281
And as always please if something is better please say why and not just that its shit lol.
And the Storm Sniper will be getting a major overhaul during this process and a build log will of course be posted as I go. First I need to find a decent el-cheapo case to house my rig in as I hack and slash the Sniper apart lol. Actuaqlly calling it a Storm Sniper after this would be wrong
as I said major changes
Product Details:
- - Rasa Black (Acetal) CPU Waterblock
- - Socket 775, 1366 and 1154 Backplates
- - Socket AM2 and AM3 mounting kit
- - X2O 750 12V Pump/Reservoir (42dB Max)
- - 5mm Blue LED with 4Pin Molex
- - RX360 Radiator
- - 80mm to 120mm Radiator brackets
- - Low Noise 1700rpm 120mm Fan x3
- - 120mm Fan Grill x 3
- - 2 Meters of Clear 7/16" Hose
- - G1/4" to 1/2" barbs x6
- - Thermal Paste
