shambles1980
so i finally got all my bits n pieces through the post now to transfet my gaming pc in to its new haf 922 case.
but the case is technically to short...
the 240 radiator on the top with 1 set of fans. (not push/pull) will not clear my ram clips. For now i have set it up a bit off set from the actuall mounting holes using some washers, and il try and get some annorexic fans. but its kind of annoying.
1 inch taller and would have been no problems at all. I just dont get why it wont fit with normal fans. it has the mounting holes for it. seems to have been designed with that as an option. Untill you actually try and install your 240 rad that is..
any way i do like the case. i got the one with the clear side pannel not the mesh.
The wire management side of things has made a huge difference. (still a bit of a mess behind the mother board but atleast i dont have to see it now)
also i was a bit dissapointed i couldnt mount a 120mm rad at the rear exhaust fan spot when there was a 240. mounted at the top.
But i managed to mount it on the 3.5" drive bay any way. and still had room for my last 120 rad at the very bottom near the PSU.
it would have been a perfect case for me it it was 1-2 inches longer and 1 inch taller.
Now its a I have to do this but it works case instead.
