Which thickness on a mousepad?
Dawelio
Active member
Hello everyone,
A little random question here, but has anyone actually used an 2mm thick mouspad over an 3 mm thick one?
I'm currently in the search for one in a specific measurement and have found one, although the 2mm is about $7 cheaper than the 3 mm one. Which is a bit odd and a rather big price difference.
I've used Glorious mousepad for the past years, which is 3 mm, but it's too small and the largest one is too big for my needs.
Although I'm wondering if a 2 mm is better in any way? Anyone in here that has any thoughts on this?
Thanks,
Dawelio
As long as your table is perfectly flat, it's pure preference. I quite like QCK Heavy, which is 4mm. Thinner isn't necessarily better or worse, but a thicker pad generally has slightly more give to it.
i do like them a bit thicker i did try one of them super hard thin ones razer sphex v2
and it was crap the tracking seems ok but the clicking was atrocious
needs a bit of cushion for da pushin as they say
