which temperature is right ?
ady_flame
hey ! so i got my watercooling kit: thermaltake 745
my bios temperature shows as 19degrees
but when i go into windows, it shows up as 37 (speed fan etc)
but when i use other programs i get lower readings than that
before:
idle~ 43
load~ 57
after:
idle~ 37
load~ 43/44
so i did get a huge drop in load temps, do these look about right ?
room temp is 21degrees
odd for a bios to be wrong but on the basis of it being a thermaltake kit i would say that your bios is incorrect. what cpu is it and what voltage are you running?
:D wouldve replied faster but login doesnt seem to work (i used the top right panel at the end :P if you no what the hell im talking about :D )
ye, im using core temp right now
so i guess my bios is wrong :D
edit! ahah i just read the news bit, that login thing makes sense now :P cya
