T tomhcb New member May 14, 2011 #1 I'm using a ASUS P8P67 Pro mobo im looking at using either: Corsair Vengeance Blue 2x2GB 1600mhz Mushkin Blackline 2x2GB 1600mhz Mushkin Copperhead 2x2Gb 1600mhz (though i wouldn't use the water cooling) All with 9-9-9-24 timings any thoughts?
D DragonPC New member May 14, 2011 #3 If you are going to use the nh d14 then go for the mushkin if not you are then you are free to choose but i recommend mushkin tho.
T tomhcb New member May 15, 2011 #4 I'm going to be water cooling so clearence shouldn't be a problem
T tomhcb New member May 30, 2011 #5 I just bought some Mushkin Radioactive 2x2GB 1600Mhz 7-9-7-24 bout £50 including shipping from USA to UK
