Kopesetic
Ok, while I'm STILL waiting on my refund to come through, I'm trying to decide between budget cases that have good airflow capabilities. I'm currently looking at 3 options.
Corsair Carbide 200R
Corsair Carbide 300R
NZXT Tempest 410 Elite
With either Corsair, I would have to use the H80i because it doesn't look like the H100i is supprted. With the NZXT it is. I'm fine with using the H80i but would rather use the H100i. However, many reviews state that the NZXT, while a nice budget case, is of poor quality. Many have commented that they receive the case with the front fans not working, the grumets do not stay in well, and the side panels are very flimsy.
Now, the 300R looks to have better airflow capabilities than the 200R and that seems to be the only difference I see. Basically I would save $10 with the 200R, but the 300R would be better down the road when I replace the fans later.
So what would you guys do? Or if you have an option that is upto $70 that you feel would be better than these, please share.
Also, in case it is asked, I'll be using a GPU between 9.5" - 11" in the new build. Haven't quite settled on the GPU just yet, but it will be within these dimensions in length.
