Hey there.
So as of recently I have upgraded my power-supply which should be enough for most single-gpu cards that's within my requirements.
I'm wondering what GPU would it take to complete max out MMOrpgs @ 1080p with smooth FPS, pref 50+ FPS for the majority of the time.
I know this is a very... Generic(?) question, if it helps the MMOs that I'll be playing / am currently playing are: Tera Online, Guild Wars 2. However I also do play other games such as Battlefield 3 which I would like to very smoothly run in medium, or even high setting.
Please note that when I say max or high, I mean shadows, textures, max view distance, etc. Not necessarily anti-aliasing, as when I put AA over x4, I start to get headaches.
I'm not looking to buy a pre-owned card, even though admittedly there are some great solutions for price. However with GPUs I only feel comfortable buying brand new.
If possible try to answer the above without a price in mind. By that I mean, what do you think could run these settings above, and no more - I don't need anything that will overkill. (Example 690, X-fire 7970).
SLI / XFire is a no go as well. - Thanks in advance.
