GoldenbanjoDJ
Hey guys,
Here's a challenge for you!!
Last night I got in after a stressful 9 hour car journey from work through floods.
My eyefinity setup has been working like a charm since Christmas with a 6950, 3 1080p LG monitors (all the same model) and an XFX mini-displayport to DVI adapter.
When I switched on the system, I was greeted by a 900p eyefinity setup. All of the icons were massive and were all aligned on the 3rd monitor, which is weird because I always have them arranged across the displays.
I thought nothing of it at first and simply right clicked and went to screen resolution. However, the maximum I could select on the slider was 4800x900 for eyefinity.
Then I went in to try and reset the eyefinity group by disabling it and then creating a new group. didn't work.
I then wondered if it was anything to do with the hardware. I switched off the computer and unplugged the mini displayport adapter from the pc, disconnecting the third display. I switched the computer on and was met with the two remaining displays arranged in an extended desktop setup, but both were in 1080p as opposed to 900p.
I plugged the third monitor back in via the minidisplayport adapter and rebooted, the display went back to 900p. The old 'switch it off and switch it back on' didn't quite work.
So I checked the properties in Catalyst and realised that out of the 3 monitors, 2 were listed as 'W2361' (the model number) and they had max resolutions of 1920x1080 and 1 was listed as 'fake' and its properties were 'unknown'. The monitor which is listed as 'fake' is the one connected via the minidisplayport - dvi adapter.
What on earth is going on? My displays are all 1080p and have been running 1080p. Displays don't just drop in resolution! The only thing I can think of is the connection between the card and the 3rd ('fake') monitor. I have tried both minidisplayport ports and got the same result.
Or is there a software issue going on here? Literally stuck.
Kind regards! Daniel
