ruthless_villain
Hi guys,
now you may or may not know that i am currently doing surgery on my tj07 so i can fit a 360mm radiator in the roof.
so i looked at it and it seems like the phobya rad grill has screw holes for m3 screws and well i have m3 screws so i was wondering what size drill bit do i use to drill the holes into the top of the case to hold the rad grill
now if i have confused you i apologise but i am modding noob but any help would be much appreciated
thank you for any help,
ruthless
ruthless
