robtmathias
Ok do I get $270 EK CPU Kit with EK-Supreme HF - Nickel block, 800 liter per hour pump, and EK-CoolStream RAD XT (360) radiator w/Yate Loon D12SH (2200rpm)fans
-OR- $259 Swiftech CPU kit w/ Apogee XT waterblock and 1200 liter per hour pump and MCR220 radiator & fans with pre-installed Radbox?
Does pump performance go beyond liters per hour ? Which waterblock is the best on the market, or is it not mentioned in these two ?
Can you guys help pick me out a better block/radiator/pump than whats in these kits ?
I am fighting what is !! 75C !! on my $70 Thermaltake SpinQ air cooler AFTER ONLY THE FIRST 2 SECONDS OF ONLY 70% LOAD in 12.7C abient
This means I need to take down what is probably more than 90C over ambient, and I'm trying to get it to no more than 40C over ambient, I need 50C of watercooling under an extreme 1.52v overclock thats good for months of 100% load folding without a break.
I am talking CPU only here.
I need the best block, plate/jet, pump, radiator, fan, and resvoir combo!
Below are some other random thoughts:
EK Supreme HF Universal CPU Liquid Cooling Block - Rev 2 - Full Copper - Nickel Plated looks nice, but I dont know if it's the best!
Swiftech Apogee XT Extreme "Flagship" Performance CPU Waterblock- also looks great, which of these is the best, or is it one of the other waterblocks on the market? Is the XT Extreme better than the Apogee XT ?
