Hello,
My PC is having weird reboot issues when switching to different saved overclock bios settings.
1. When I change to different bios settings for different stable overclocks the pc won't boot, the pc will shut down but doesn't turn back on after that.
What I do to make things work again I unplug my PSU for a few seconds or minutes depending on my situation then replug the PSU then press the case's power switch. It then brings me to the "choose your settings" screen, then I type "Alt+xnumberx" then reboot.
2. When I reset CMOS the PC will not turn back on from the get go like before, it used to just turn back on and I'll go on with my day.
3. Now when I try to reflash the bios it doesn't reboot till I do #1 and #2.
What I was thinking at first is the boot order saved in the overclocked bios settings, but I never changed anything. I have a few overclock settings saved ranging from 4.5Ghz-4.8Ghz with nothing changed in the settings but settings associated with overclocking my CPU/RAM.
Another thing I've noticed is if I get past all this and resetting the motherboard to defaults and JUST setting XMP/memory voltage it won't restart like it normally does before.
Is my OS boot order corruped or screwed up?
Is my PSU about to Die isn't properly power up the motherboard?
This PC is fairly new and these issues has me amazed that it's already breaking down so fast.
I don't want to have to RMA my motherboard again, then have to wait for a different one.
But if I have to then so be it, but if I have to do it again, then that would suck a lot.
Anyways enough of my rambling...
Any thoughts on this matter or ideas what could be the cause of this?
Thanks for your time...
System Specs:
Board: MSI Z97 Gaming 7
BIOS: 7916v1B
VGA: Gigabyte GTX 970 G1 Gaming
PSU: EVGA 850 Watt Gold Silient
CPU: Intel® Core™ i7-4790K Processor
MEM: 2x8GB, G.Skill Ares 1600Mhz 9-9-9-24 1.5 volts
HDD/SSD:1x Crucial MX100 256Gb, 1x Seagate 2 TB
COOLER:Swiftech H220X Nemesis L Series 360mm radiator
Keyboard: Razer Blackwidow Chroma, USB
Mouse: Razer Deathadder Chroma, USB
OC: Stock/4.7Ghz Overclock
OS: Windows 10 64bit Professional
System Specs:
BIOS: 7916v1B
