Just thought some of you guys might like to know... Was building my PC on an Asus P8P67 Pro with some Mushkin Redline Ridgeback PC317000 RAM (2x4GB @ 2133MHz) and it just wouldn't post on it's first ever run. Using the mobo's nice LED's for showing up faulty components, it showed a RAM problem. I tried to get it to post using the MemOK! function which automatically selects a bootable speed and timings for the RAM, but it did not work.
In the end I found that my motherboard would not support this memory in 4GB or 8GB for initial startup, even when running at the stock (not XMP) profile of 1333MHz... Bit weird eh?
In the end I got past post by (luckily) ripping a stick of 1GB DDR3 from my other computer... After post I put the other sticks in and everything works fine.
Just a bit weird... thought I might share! Asus says the RAM is fully supported and it blatantly isn't.
