Gamepro105
Hello every one,
So i'm looking for 2 X 200mm fans to put in the front of my corsair 600t case as i took out the drive cages and mounted the two stock ones that came with it, the problem is there just not overly powerful or quiet so far ive spoken to feronix ,Bousatsu and mArTyN we have found these:
NZXT FS-200 - http://www.overclockers.co.uk/showproduct.php?prodid=FG-002-NX
NZXT FZ LED - http://www.nzxt.com/product/detail/121-fz-200mm-led-case-fan.html
Bitfenix spectre pro http://www.bitfenix.com/global/en/products/accessories/spectre-pro-led#gallery
It worked! ^
My question is what ones are the best for air flow? As i am trying to provide extra air flow through the case to reach the radiator of the h100i and the air cooled XFX 7950
and
Are there any other better alternatives?
Thank you!
It worked! ^
and
Thank you!
