Karlos_the_n00b
what do you think![]()
Your case looks mint mate.
Thanks dude!
BTW as it says on my first post now
EDIT:>>>>>>>>>>>>>>>>>>>>>>>>>
after the 6 series call back i used that as an excuse to upgrade.....
I will post the new specs up soon,
this is what i have so far
- mobo will be the P67 UD7
- all will be water-cooled (cpu only)
- gpu will be gainward phantom gtx 570
- PSU will be corsair ax850w
- ram will be 8gb dominator gt's with the blue fins they look shexshi
this is it so far, i will post up more updates as the build progresses as im currently stressing over exams
arghhhhhhh
arghhhhhhh
Mate Z68 UD7 has already been spotted on shop shelves in Taiwan, if you haven't bought a new mobo yet hold out for a bit for that one to come available in your country.
In what way will it be better than P67 I havent bought it yet![]()
Don't know the full details yet, but what is currently known is it's a combination of H67 and P67, best of both worlds (overclocking and on board graphics is what we're certain of at the moment).
However that's not the only reason you should get one that's currently known. Gigabyte is no longer going to be looking in to P67, but rather put more in to Z68, read here. Therefore there will be more long term support on the Z68 chipset (BIOS updates etc.).
You can read about the Z68 UD7 here as well if you want to look at all the info which I'm sure you will.
had a quick read, its defo worth waiting for which is probs what im going to do but looking at what these websites are saying and the pictures it seems that the Z68 ud7 doesnt have a display output which sort of defeats its purposes does it not??? :s
Which is what makes me think there's more to Z68 than we know, it couldn't warrant another UD7 class board otherwise.
Hey Guys,
I have Finally Completed My Rig![]()
Specs Are As Follows;
-Core i5 2500k OC'd to 4.7Ghz at 1.325V
-Mushking Redline Ridgeback Ram 2 x 2GB (6-8-6-24 1600Mhz) OC'd to 1833Mhz at 7-9-7-24 Timmings
EDIT*
i chucked in 2 more 2gb sticks of mushkin redline ram and i overclocked the 4 stickes at 2133 at 10-10-10-26!!!!!!!!!!!!!
-HD6850 Toxic Sapphire 820Mhz OC'd to 900Mhz (will go up to 1000Mhz but Didn't need it) at 1.00V (heaven Benmchmark Gave a 808 result reading, Max temp 75'c)
-MSI P67A-GD65 Mobo
-NH-D14 Cooler
-Corsair HX750W PSU
-Kingston V100 64GB SSD
-1TB Samsung F3
-Samsung Blu Ray Drive
2 x NF-P14 Fan's
The specs above was what the rig used to be but after the 6 series call back i used that as an excuse to upgrade.....
- ram will be 8gb dominator gt's with the blue finsthey look shexshi![]()
arghhhhhhh
Lol not so hard, just set the ram at 2133mhz then played around with the latency timings till I got a stable system, memtest helps alot when stressing the ram and making sure the ram is stable![]()
Ofcourse I'll helphmm I think raven 02![]()
Because you are air cooling and tbh the collOssus isn't the best for air coolingso stick with that raven it's sed to be the best air-cooling chassis....![]()
Other then that everything else seems perfect, so good luck, if yOu need anymore help were all here 4 you![]()
Have fun with your super build xD
Thats the thing DX I mean it is one of the better looking performance cases but it is still kinda bland for me and to top that off I want to switch to watercooling in the future so I am kinda stuck :T but who knows, I may just take this thing to my High Schools metal trades class and we use this to make a freaken Lamborghini be put to shame XD
