Watercooled BitFenix Colossus Project Finished
hey all,
i have modded my side panel, so now it has a LED window
let me know what you think!!!
without LED
Blue LED
red LED
this is perfect
this side panel mod is soooooooooooooo nice, as it gets u the window and u keep all the features of the colossus that u would've lost with the windowed version
congratz, can't wait to see it all put together
Yup I will put it all up here once completed.
Thanks
Still undecided about the colour scheme :/
well guys heres an update,
White Noctua's
Sprayed Panel
Finished panel (the chaulk strip on the right side needs ajusting a little
btw im going to for a blur coulour scheme ill keep you all updated as it progresses
What kind of spray paint did you use Firat? I might have a go at spraying my Noctua fans a different color.
heres the link for the spray paint i used The Link
make sure 20mins after spraying turn the fans on and let them dry themselves so that the paint doesnt affect the fans movement after it drys
Heres a quick update everyone
what do you think
looking really good
(and btw i'm in biochemistry too
haha but my love of computers is making me switch out of my 3rd year to go into computer software engineering next year i'm super excited to learn how to create/manipulate computer software cuz then you can do anything
what do you think
Sweet.
I can't tell from the picture, excuse my ignorance, but if you have any watercooling tubes fill them with the same shade of blue as the light but put a band of black tape alternating every so many cm (eg. 2cm band of tape, 2cm gap, 2cm band of tape, 2cm gap...) then you'll get a glowing blue band effect around the tubes to complement the front panel.
Sweet.
Not a bad idea, I will be watercooling so once complete we will c what happens
looking really good
I can see why you ran away from biochemistry, lucky guy, hope the new course goes well for you
