lullerkitten
Hey, I was hoping u guys could help me with choosing out the right components for my first watercooling setup
My pc specs:
Intel Core2 Quad CPU Q9550 @ 3399.97 MHz (400 * 8.5)
Asus P5Q DELUXE
Radeon HD 4870
4096 MB DDR2 Dual Channel
I was thinking about buying these parts for the setup:
Arctic Cooling MX-3
CPU waterblock : EK-Supreme LT - Acetal (775/1156/1366)
EK-Backplate CPU LGA 775
Pump : Laing D5-MCP655 12V 1/2"
Fans : 3 x Yate Loon 120MM D12SL-12 Clear+Blue LED 1350RPM
Radiator : Black Ice GT Xtreme 360 Black
Tubes & fittings : 4 x Tube clamps 12MM - 20MM (7/16 - 1/2) RVS Zilver
2 x 13MM (1/2) Bitspower Screwfitting - G1/4 (2 parts) Black Sparkle
2m Feser Tube UV - HighFlow - 1/2 ID - 3/4 OD - BLUE
Reservoir: DangerDen 5.25 Single Bay
When I'll have some more morey and can afford a new gpu i'll be adding it to the loop with a waterblock thats why i've gone for the 360 radiator and i'm hoping to get some more out of my current oc from the cpu
Is it going to be good enough and will the tubes and fittings and clamps fit together?
Thanks in advance
My pc specs:
Asus P5Q DELUXE
Radeon HD 4870
Arctic Cooling MX-3
Thanks in advance
