Hi WC pros.
Has anyone here tried moving away from water based coolant & swapped it out for oil?
I've got the usual sort of setup: DD Maze4 CPU + GPU block, twin 360 BIP rads with 6x 240v 120mm Papst fans in pull configuration, self-made plexi-res. My setup's partially run in 15mm copper with reinforced plastic tubing for attaching to blocks.
My thinking is that the oil being naturally adept at heat transference, will be great for carrying the heat away. I also won't have to worry about corrosion. And in the (cross fingers) event that I may spring a leak, my precious understated hardware should'nt go fizz-pop!
I guess the deciding factor is the choice of pump. I've taken a chance & grabbed a 1750l/hr Hailea pump on eBay. It's a monstrous lump & in bath tub tests I had a cracking time drying off the ceiling, lol.
I'd be grateful for any advice from ppl who have tried oil in the past, ie. pros & cons.
