CdwNHD
Hi guys, I need some info on a water cooling loop I wanna do.
So, i got the 'Sharkoon QB-ONE' pc case, which supports a dual 120mm or (240mm) at the top of a maximum 5cm(50mm) height(no fans) or 2,5cm(25mm) height(with fans). Also I can add a 8cm(80mm) rad at the back of the case.
GPU: EVGA SC 1060 6GB (ITX)
At first i wasn't planning to go water, but i think i can improve the temps, currently at 70ºC on max (aida64 StressTest / Forza H / The Division).
Idles temps are great at 29-39ºC.
I plan on getting a copper rad, cause i don't want to worry about corrosion.
BUT, if i add both the cpu and gpu on the same loop, will temps drop ? which rad tickness should i get ?
Parts so far:
CPU Block - banggood link
GPU Bloco - banggood link
Pump - aliexpress link
90º fittings x 2 - aliexpress link
barb fittings - 4 - aliexpresslink
Reservoir - Swiftech MCRES-Micro - Rev 2 (cause of the tiny space in the itx case)
Concentrate - EK-CryoFuel Clear Concentrate 100 mL
I already got a be quiet 120 pwm fan that i'll probably use. If not maybe i'll get 2 Vardars.
I still have to buy the rad and the tubing.
There will be a quick disconnect for draining the loop. This will be easilly acessable tru the side panel.
Let me know what you think about what rad i should get to dissipate all the heat.
Parts so far:
