Blade Runner
I have a Surface 3 which I use when I am out of the office to view files. To make sure I have everything I use MS Onedrive with all my work files available offline.
I have installed windows 10 numerous times now and it works great APART from Onedrive, when you click on the little cloud it starts up with the "Lets get Started" Pop up but then always says "Program is shutting down" and the little cloud disappears.
I have searched the web and cant find a solution, I've tried doing it both signed into my MS account and not signed in and also with only a handful of files synced prior to the upgrade (My main files are about 25GB )
Can anyone suggest anything else I could try?
