but if it passes thats a nice clock and volts fella and temps.
you might be able to go a lil higher if it pases linX
maybe ill try a little nudge down voltage.
this program is very hard on cpu.
i would of thought a 10 run would be ok
if it failed on the 19th i would restart and run again just to be sure
but if it fails at the 19th again then 1 bump in volts will get it stable
yeah linx is hardcore mate really works ur system out should pass it with the extra bump from the failed 19 pass
you got your overclock up to 4.6ghz?
yeah i know what u mean everything but my bios and cpuz is reading 3.6 but its 3.8
i think 4.2 will easily be more than u need mate, i did have 4 but with it sittin at 3.8 im not even using that to its full whack but gonna have to go back to 4ghz when i get my nice new ram so i can run it at its rated speeds
yeah mate redline ridgeback courtesy of the awsome muskin!
