Vista usbport.sys 500hz mouse polling rate.
name='WC Annihilus' said:
Hmm, I have my mouse at 1000hz... Should I turn that down? (and yes, I did set that cause I thought it sounded cool :p)
500hz should be more than enough. I would imagine the difference between 2ms and 1ms is negligible.
Houston we have a problem.... Replaced the old file with the one in the file and renamed it usbport.sys, rebooted Windows, no USB. :confused: WTH is goin' on here?
I best be able to get in to the god damn repair console and change it back to the old file.
Dude, I've had a few people downloading the file on here and renaming it to usbport.sys - you didn't do that did ya?
Yeah... I renamed the extracted file obviously, not the zip.
For some reason there was a problem with the zip file under certain versions of winrar. This is now fixed.
name='krest' said:
Is there any files for vista x64? i need it.. cuz my aim is totally gone!
I did see the x64 one floating around on the net when I was searching google. I can't remember where tho. I'll see if it's still in my history when I get home tonight.
hmm, seems it doesnt work here, extracted the file, renamed and neither 1000 nor 500hz one works, also ive reckognized that my original usbport.sys is a 220kb file while ur modified ones are only 105, something doesnt fit cause i dont belive that just changing the poll rate is reducing the file size so much :O
You need to unzip the file mate. When i open those zip files there is a usbport.sys in each of them sized at around 220k
name='Crisao23' said:
BTW, even after running the "run" commands, I had to manually take ownership of usbport.sys before replacing it.
Did you replace the bits that say "username" with your username?
Yes. Maybe it's a UAC issue.
I'll do it again on a virtual machine and check it out.
Forget about it. It was a punctuation/typo error.
All fine with cmd line.
Sorry for the mess.
Sorry for the mess.
No problems :) Just out of interest, are u running 500hz or 1000hz?
I was never able to get this working on Vista Business x86, tried about 5 times :(
I just tested the 1000hz file, proper installed. The mouserate app show me a 400+hz polling rate and no 1000Hz as I was able to use under Windows XP.
